Machine Vision
NI VBAI TCP Communication With Staubli CS8 Controller
sorry forgot to say that, I am not able to find any other versions of HTerm. could you please send some links of other versions?
Thank you.
Shiva.
Message 21 of 30
(2,875 Views)
Sorry, Couldn't send you attachment I dont know whats the problem, can you write a Email to: mshivasharan@gmail.com so, that i can send you a attachment via Email please.
Thank you.
Shiva
Message 22 of 30
(2,870 Views)
Hi Shiva, i saw you had been working with the robot Staubli and the controller Cs8 and the ethernet connection, please i want to know how i can work with a PLC s7300 sending info via ethernet to the cs8 controller.
Message 23 of 30
(2,740 Views)
Do you want to send data using EthernetIp or just Ethernet?
-Shiva
Message 24 of 30
(2,731 Views)
Hi Shiva
I am just trying to send a bit with the PLC and i want  the robot get it and after he will answer wIth another bit, but i dont know how to do it in Val3 and how to configure the CS8 controller. We are using just Ethernet.
Message 25 of 30
(2,712 Views)
I have no idea about the communication between PLC and Ethernet. But it should be the same as this communication. Please follow the document. Instead of Hyperterminal use PLC. If it Doesen't work, you could tell me specifically. So that I will look further and I will try to find out a solution.
R u using AplicomIO?
-Shiva
Message 26 of 30
(2,689 Views)
Ok lets try this..
--> In your Staubli robotic suite you will find an option physicalIOs
--> click on it you will see an option Modbus IO Config
--> Here you can add all your Digital and Analouge outputs using options below Topic name and TCP Port
--> Initially add 2 Digital Inputs and outputs
--> Enter correct TCP Port number
--> Export the XML data
--> Save this data in your PLC IO folder
--> Restart PLC and Scan the Device
--> try sending and receiving IOs
Hopefully It will help you. Good luck and Let me know the status.
-Shiva
Message 27 of 30
(2,642 Views)
Hi Shiva,
I tried by the way you told me but the robot doesnt answer  and the PLC show that it is activating the bit but the robot doesnt act or do something.Thank you
Message 28 of 30
(2,609 Views)
Ok cool!!! Give me ur Email Id we will communicate through Email. I ll try to work on it again on Monday and I ll let you know.
-Shiva
Message 29 of 30
(2,598 Views)
hello mshiva ,
i have the same situation , could you please help me how tp establish communication between plc and the CS8C or guide me through .
thanks
Message 30 of 30
(1,765 Views)
