Machine Vision
NI Vision Assistant works in Dsp tms 320C6713?
I wish to know if the Express VI of Vision Assistant can be dumped into the DSP tms320c6713?? I'm working on image processing & wish to know if the mentioned processor is suitable for my code.
Thank you
Shilpa Karkera,
Labview enthusiast.
(3,827 Views)
Unfortunately, the DSP tms320c6713 is not supported by the Vision Development Module.
You will only be able to run Vision Development Module, and download the Vision Assistant Express VI on targets that can run LabVIEW Real-Time.
You can find a list of real-time vision tagets on these pages:
http://sine.ni.com/np/app/main/p/ap/vision/lang/en/pg/1/sn/n17:vision,n24:embeddedVision/
http://www.ni.com/white-paper/13045/en
Also, someone has also interfaced LabVIEW with NVIDIA GPUs using CUDA. Here is the link to the toolkit:
http://forums.ni.com/t5/Machine-Vision/ADV-Toolkit-Imageprocessing-on-NVidia-GPU/td-p/1130963
Christophe
(3,819 Views)
Are there any cheaper processors... such as ARM 7 that work with vision acquisition/assistant?
(3,789 Views)
