Machine Vision
NI Vision Builder AI 2018: Inquiry -- "Inspection Selection" Failed to Switch Inspections
Dear NI Support,
Please advice regarding the issue of switching between inspections for NI Vision Builder AI 2018.
1) Two inspections "tut chap 2.vbai" and "tut chap 3.vbai" are created.
These two inspections are essentially the examples in the manual "NI Vision Builder for Automated Inspection Tutorial".
2) The "Inspection Selection" is included for switching between "tut chap 2.vbai" and "tut chap 3.vbai".
Attached are the screenshots of steps used in configuring the "Inspection Selection".
3) The "Inspection Selection" feature failed to switch between the inspections "tut chap 2.vbai" and "tut chap 3.vbai".
Please advice regarding the steps in the screenshots attached as well as the solution to this problem.
Thank you.
(2,485 Views)
Accepted by topic author JN123
This is a known issue that was fixed in VBAI 2018 SP1:
https://www.ni.com/en/support/documentation/bugs/18/ni-vision-builder-ai-2018-and-2018-sp1-bug-fixes...
705501 Select Inspection State does not switch between inspections when using previous measurements
Try updating to VBAI 2018 SP1 or VBAI 2019.
Hope this helps,
NJ
(2,429 Views)
Thank you for the suggestion, it helped. Updated to VBAI 2019 and the issue was fixed.
(2,406 Views)
