Machine Vision
NI Vision Runtime Licenses
I would like to be able to distribute a vision application but do not see a way to do this with the current NI licensing policy.  It is unfortunate that NI still is requiring a individual runtime license in the first place but even more unpleasant is that there is no way to build the licensing into a distributed application.  Each end user would need to purchase their own runtime and register it.  If the vendor (myself) wishing to purchase bulk licenses then they are coupled to the vendors NI account and would have to be individually transfered one by one to each end user.  Is there a bettter way to do this?
(4,473 Views)
Have you discussed this with your local sales engineer? I'm not sure if they would have a definitive solution to this problem, but they could definitely escalate this problem up the right paths to see if some solution can be found/created.
(4,417 Views)
