Machine Vision
NI Vision Template Editor
I am running an eval version of VBAI I just downloaded.
I went to Geometric Pattern Matching and wanted to do
a new model. I saw the help button and it takes you
to NI Vision Template Editor instructions. I do not have
many of the items discussed in the Context
Sensitive Help on my Template Editor Screen, specifically
"add contours" also no selections of sources like a
previous image or golden image.
Anyone know why This feature NI Vision Template Editor
is not showing up with all the features shown in the
VBAI context help.
(4,489 Views)
Hi viewman,
I may be able to say more if you can point us to exactly where you are seeing these options in the help as I was unable to locate them. A screenshot or your environment (with the discrepancies labeled) will be helpful in figuring out exactly what is going on.
Cheers,
Andy C.
Applications Engineering
(4,448 Views)
