Machine Vision
NI Vision Tutorial - basic fundamentals
you could perform Hough line transform and extract the three lines of the triangle and continue from there. There are possibly quite a few methods to do this (particle analysys, geometric matching, edge detection, etc...).
But as muks said, you should start a new thread with more detailed information about your setup and problem.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 21 of 23
(2,298 Views)
Hi
I would like to know the tool caliper in the NI Vision. What mean the blue and red lines, the step and other sets.
Message 22 of 23
(2,086 Views)
Hi alexandresantos,
Here is the help which may Help you better understand the functions. Could you please create a new thread for this question as it is an older discussion and will have more visibility if it is placed in a new thread?
Paolo F.
Message 23 of 23
(2,068 Views)
