Machine Vision
NI Vision and NI-IMAQ on Windows Server 2008 x64, cannot use more than 2GB of physical RAM??
I'm trying to make one application to work on Windows Server 2008 Standard x64. The application works on 32 bit windows versions with no problems.
Here are some details:
* OS Windows Server 2008 x64
* RAM 2*2GB dual channel memory
* card: PCI-1428
* software and drivers: NI Vision Acquisition 8.5.1 with NI-IMAQ 4.0
* development environment: Visual Studio 2008, C++/MFC
The software links the imaq.lib and niimaq.h.
I followed the recommendation from this thread: http://forums.ni.com/ni/board/message?board.id=200&message.id=16267&query.id=171742#M16267, installed NI-IMAQ 4.0, loaded the new library and header, and recompiled.
I'm getting the following error after imgSessionAcquire: "This 32-bit device is operating on a 64-bit OS with more than 3GB of physical memory.  This configuration could allocate 64-bit memory which is unsupported by the device.  To solve this problem, reduce the amount of physical memory in the system."
The code looks like this:
    if( (error = imgSessionAcquire(sessionID, TRUE, NULL)) != IMG_ERR_GOOD)
        imgShowError(error, text);
        TRACE("imgSessionAcquire returns error: %s (%ld)\n",text,error);
        return false;
To make sure that the message was valid, I found a pair of 1GB RAM modules. Rebooting the system with only 2GB, the application runs like a charm.
Now according to BlueCheese in the thread I mentioned above, using the newer version to NI-IMAQ and Vision should have solved my problem.
I would need to be able to run our application on this server with much more than 3GB of physical memory. Would anybody have any advices and/or suggestion to help me solve this issue?
Thanks in advance,
-Damien
Message Edited by Specim on 01-23-2009 02:02 AM
(3,516 Views)
I'm replying to my own question if someone need this information somedays.
The link to the supported devices is still valid even for NI Vision 8.5.1 http://digital.ni.com/public.nsf/allkb/8F88EFCCB94AE3408625722900579A4D?OpenDocument
The firmware of the PCI-1422 and PCI-1428 we are using are not compatible with other development environment than LabView under x64 based system.
Moving to a PCIe card, PCIe-1427 for single channel or PCIe-1430 for dual channel would solve the problem for Camera Link cameras, as there is a firmware upgrade for both cards enabling non-LabVIEW development to use more than 3GB of RAM for the OS.
To update the device firmware, launch MAX and select Tools>>Ni Vision>>Update NI-IMAQ Device Firmware.
No solution yet for the PCI-1422 (LVDS). I'm not sure how reliable is a LVDS to Camera Link converter.
-Damien
(3,509 Views)
