Machine Vision
NI Vision module support for LabView 2019
Dears,
I'm mouving an acquisition Video System using FireWire acquisition Board form a PC1 to an other PC2.
The acquisition system was run on PC1 wiht LV2013 32bits.
The acquisition system now will run on a PC2 with LV2019 32bits.
After the installation of LV2019 and Vision Acquisition (IMAQdx), the frame graber is detected in MAX and all are working well.
However, when I want to run VIs on the PC2 which was write on LV2013, LV2019 put a warning :
NI Vision module support for LabView 2019 is missing. (Get_pixel_value.vi, Get_image.vi, all basic vi from vision are not installed.
Therefore, within NI manager, I download NI Vision development module_19 and start to install it but I have this message from NI package manager :
Could not find product 'ni-vision-developement module_19'
and the installation stop.
Have you a solution to fix this issue ??!
Best !
(1,597 Views)
Dear,
It was a mismatch during the LV2019 installation, since the name of the module is now Vision Assistant.
The issue is fix.
Sorry !
Best to all,
(1,589 Views)
