Machine Vision
NI measurement palette is not shown in function.how can i install?
Message 1 of 11
(4,560 Views)
What is your lv version? Do you have this lib C:\Program Files\National Instruments\LabVIEW xx\instr.lib
Message 2 of 11
(4,561 Views)
My labview version is 2009. I wanted to access the usb palette. I have already installed VAS,VDM and IMAQ USB. But the usb palette is not appearing. I also don't have 'ni measurement' palette in functions. What i have to do?
please help...
Message 3 of 11
(4,559 Views)
Yes i have instr.lib in my labview..
Message 4 of 11
(4,558 Views)
Which version of IMAQ usb did you install?Do you have the instr.lib in the location as mentioned above but i still feel it should affect it much.
Message 5 of 11
(4,556 Views)
sir, I have installed labview 2009.. then I have installed all the following modules:
1) Vision aquisition software
2) Vision development module
3) Vision development patch
4) IMAQ USB installer
But when i load my application in labview it is unable to load 6 things: IMAQ USB open,IMAQ USB Close,IMAQ USB GrabAcquire,etc.
what may be the problem if i have installed all the things correctly. I am unable to see the measurement palette in functions menu in block diagram.
please help...
Message 7 of 11
(4,550 Views)
IMAQ for USB was built for an older version of LabVIEW and won't install for LabVIEW 2009.  You should be using NI-IMAQdx 3.4 or later which is part of Vision Acquisition Software.  You will  have to replace the IMAQ USB functions with the equivalent NI-IMAQdx functions.
Message Edited by A Person on 03-19-2010 03:57 PM
Alex Person
NI-RIO Product Support Engineer
Message 8 of 11
(4,529 Views)
Sir, But when i am opening my project containing IMAQ USB components in Labview 8.6... It is displayed that "This project is created with higher version of labview.So pls open with higher version". What may be the problem?
Message 9 of 11
(4,516 Views)
How can i update my labview 8.6.0 to 8.6.1... pls give me the link..!
Message 10 of 11
(4,513 Views)
