Machine Vision
NIOCR with CVI 5.0
I have installed NI OCR (Version 1.0.2) on CVI (Version 5.0). When I start running of CVI, pop-up message appeared as "Not a valid function panel file" "C:\Cvi\bin\niocr.lfp". And function library of OCR dosen't appear on library menu. I install CVI(5.0),IMAQ Vision(5.0) and NI-OCR(1.0.2) on fresh PC then faced the same problem. What shall I do?
(3,045 Views)
Try to manually load the function panel for the NI OCR toolkit instead. Then you should be able to use it in CVI.
Hope this helps-
Julie
(3,045 Views)
