Machine Vision
Need help and advise on learning VDM
Hi all,
I am new to VDM, was given assignment to develop machine vision program in vb.net or c#.net using VDM library.
I am looking for some advise on resources or site that will help me to learn VDM in the short possible time, I would appreciate if anyone can helkp to advise on this subject.
Also, I am willing to paid a reasonable fee if any person can help and guide me personally in this subject.
regards
eclim
(2,026 Views)
Hello Eclim
I am assuming that you are referring NI VDM (since you mentioned VB and C#). Learning basics of VDM is not rocket science. I recommend you to get started by
> Exploring NI Vision Assistant - Open images and try some functions.
> Then start going through NI Vision Concepts Help (.pdf /.chm file), which contains the concepts behind image processing algorithms.
> Then understand how image buffers and different image types are handled.(Use NI help - Ctrl + H)
Hope this helps !
-Rahul
Hit KUDOS for Thanks
(2,000 Views)
Hi Rahul,
Thanks for your advise.
regards
EC Lim
(1,978 Views)
