Machine Vision
Ni-IMAQ for ieee1394 - format 7 problem
Hi!
I've encountered a bad problem using a Hamamatsu ORCA-ER camera with IMAQ for IEEE1394 v 2.0 running on Windows XP SP2 with LabView 7 (the problem is there also on labview 7 running on windows 2000).
My VI does a triggered snap to get a single image from the camera. Image acquisition is triggered by an external TTL in mode 1. This works just fine until I change the format 7 parameters (binning). The first image after changing the binning is acquired without problems, but when trying to acquire a second image, error -50150 is always generated. I tried all sorts of variations on the VI without success.
If the format 7 parameters are left unchanged after the error, the third and all subsequent images are acquired without problems. If the format 7 parameters are changed again after clearing the error, Labview crashes and can only be closed through the task manager. If, after the error has occurred, one tries to switch to a program that does a continuous grab, Labview also crashes hard.
The problem is really halting my project, and any help would be greatly appreciated!
Anders Fridberger
(3,932 Views)
Anders
What are the format 7 parameters?
Can you send a copy of your .icd file (located in C:\Program Files\National Instruments\NI-IMAQ for IEEE-1394\Data) of the configuration that crashes LabVIEW?
Can you send a simple example that demonstrates the crash?
Have you tried using a triggered grab instead of a triggered snap?
Regards
Johann
(3,925 Views)
Dear Johann,
I attach a scaled-down version of the VI. The overall intention with the program is to synchronize image acquisition with a series of laser pulses delivered from an Nd:YAG laser. By increasing the "Laser Pulses per image", a longer TTL signal is generated. The trigger is generated by an E-series board. Each time the user presses "Get image", one trigger is generated, a burst of laser pulses occurs, and an image acquired.
The only format 7 seven parameter that the program modifies is the binning. A value of 0 means no binning, the image is then 1344 x 1024 pixels. A values of 1 gives 2 by 2 binning (672 x 512 pixels) etc.
Normally, image acquisition is a rather infrequent event during the experiment (the maximum rate is one image per two minutes or something similar). This is why I use a snap. I believe that I tried using a grab at the beginning, but then, there are timeouts and similar problems because of the low rate of TTL pulses.
The ICD file is reproduced below.
Thank you,
Anders
[NIIMAQ_HEADER]
Type = 2
Version = 6
[1394_CAMERA_DATA]
Brightness = 255
AutoExposure = 0
Sharpness = 0
WhiteBalanceUB = 0
WhiteBalanceVR = 0
Hue = 0
Saturation = 0
Gamma = 0
ShutterSpeed = 1100
Gain = 0
Iris = 0
Focus = 0
Temperature = 0
Zoom = 0
Pan = 0
Tilt = 0
OpticalFilter = 0
VideoFormat = 7
VideoMode = 0
VideoFrameRate = 0
TimeOut = 5000
Format7Left = 0
Format7Top = 0
Format7Width = 1344
Format7Height = 1024
Format7ColorCoding = 6
Format7BytesPerPacket = 3440
AbsoluteBrightness = 0.00000000000000000e+000
RelativeAutoExposure = 0.00000000000000000e+000
AbsoluteSharpness = 0.00000000000000000e+000
AbsoluteWhiteBalance = 0.00000000000000000e+000
RelativeHue = 0.00000000000000000e+000
RelativeSaturation = 0.00000000000000000e+000
AbsoluteGamma = 0.00000000000000000e+000
AbsoluteShutterSpeed = 1.00098244845867160e-001
RelativeGain = 0.00000000000000000e+000
AbsoluteIris = 0.00000000000000000e+000
AbsoluteFocus = 0.00000000000000000e+000
AbsoluteTemperature = 0.00000000000000000e+000
RelativeZoom = 0.00000000000000000e+000
RelativePan = 0.00000000000000000e+000
RelativeTilt = 0.00000000000000000e+000
AbsoluteOpticalFilter = 0.00000000000000000e+000
UserRoiLeft = 0
UserRoiTop = 0
UserRoiWidth = 1344
UserRoiHeight = 1024
Format7Speed = 3
IgnoreFirstFrame = 0
ShiftPixelBits = 0
SwapPixelBytes = 0
BitsPerPixel = 12
TriggerDelay = 0
WhiteShadingR = 0
WhiteShadingG = 0
WhiteShadingB = 0
FrameRate = 0
AbsoluteTriggerDelay = 0.00000000000000000e+000
AbsoluteFrameRate = 0.00000000000000000e+000
ColorFilter = 0
ColorFilterGainR = 1.00000000000000000e+000
ColorFilterGainG = 1.00000000000000000e+000
ColorFilterGainB = 1.00000000000000000e+000
(3,915 Views)
Hello Anders!
Have you resolved your problem or is it still an issue?
Ashwani S.
National Instruments Sweden
(3,872 Views)
Hi Ashwani,
The problem is still there, and it reproducibly occurs every time that the binning changes, if mode 1 (level) triggering is used. The only workaround that I've been able to find is to use mode 0 triggering instead, setting the exposure time based on the expected duration of the trigger signal. This works, but it is not an optimal solution.
I saw recently that similar problems have been reported previously by somebody else using mode 1 triggering and binning, so the problem is not unique to my hardware or VI.
Thank you,
Anders
(3,865 Views)
Hi Anders!
I´m sad to hear that you didnt find a solution to your problem. I will escalate your issue to our R&D department.
Cheers
Ashwani S.
(3,863 Views)
