Machine Vision
No communication with camera ! Check the wiring or restart the system.
I have been having the Communication with camera error with my VI. The VI is to connect the Microsoft USB Camera and to take a picture. This issue is a random issue and I have been trying to find the solution but no luck so far.
Please have a look at the attached image and guide me. I appreciate your help.
Thank you
(2,141 Views)
Hi Tapanpatel9024,
First I would check if your camera is supported by NI software using the link below:
Cameras Supported by National Instruments
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6COSA0&l=en-US
Then the link below has the initial set up and troubleshooting steps. Generally, we would want to verify the camera functions correctly in NI MAX before trying to run it with a VI.
Getting Started with USB3 Vision Cameras and NI Vision Acquisition Software
http://www.ni.com/tutorial/14423/en/
Jiwhan S.
Technical Support Engineer
(2,075 Views)
