Machine Vision
Non linear continuous crack detection
Hello
I am trying to figure out an effective method for Vision Builder to have an automated system to detect cracks and defects.
We were able to filter out the image to have a consecutive line of pixels.  My question is "How do I make Vision Builder to determine
that the continous pixels are in fact a crack so it can fail the process?"
Here is a picture of what I am working with
[IMG]http://img.photobucket.com/albums/v356/stickydiljay/crack.jpg[/IMG]
I appreciate any input. Thanks in advance
(5,010 Views)
Hey Diljay,
I believe you can do this in multiple ways:
1- Edge Detection
2- Morphological Analysis, fining particles and their sizes
3- Pattern Matching
I hope this helps
A. Zaatari
(4,977 Views)
I need to detect the crack in eggs can someone please help me on this
(4,546 Views)
As a starting point, I would try using a threshold function to see if you can pick it out sufficiently. You might also explore lighting options to help eliminate shadows, such as using multiple lights at different angles.
(4,511 Views)
sir i tried edge detection and then i tried to remove the crack alone from the egg shell but i couldnt can you tell me how to do it
herewith i have attached the edge detected image of egg for your reference
(4,495 Views)
Before you get too far on the algorithm I would spend some time on the image acquisition.  You should try to get some lighting to eliminate shadow and glare and select a background that will be quite different from the egg if possible.  Now you can seperate egg from background and mask the egg.  I would probably follow this with a threshold to get the crack candidates and filter out particles that tont have characteristics of a crack like the thickness of the particle is too wide (I have done this using a danielson on the bianry and refiltering by max distances from edge) .    Would have to study many samples to understand the nature of what defines a 'crack'.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,425 Views)
