Machine Vision
Number of frames limit using Dalsa Camera (mem alloc)
I am having difficulty combining a Dalsa CL-CB-1024T Linescan camera with
IMAQ Labview
software.
Basically the program successfully grabs images from the camera using
the PCI 1424 framegrabber, as long as the number of frames (Depth) does
not exceed 100.
I thought this must be a memory allocation problem. However, the IMAQ
Configuration List vi used in the IMAQ Sequence vi has set memory
allocation to system memory. I tried changing memory allocation to
onboard memory (PCI1424 should have at least 8Mb) using the IMAQ
Configuration List vi. Although this allowed more frames to be grabbed
(800) none were displayed. No errors were indicated.
Is there anyway to increase the system memory allocation si
ze for the
frame grabber? Or do you know how to config the IMAQ Sequence vi to use
the onboard memory properly?
Message 1 of 1
(4,845 Views)
