Machine Vision
OCR example modify for WebCam
Hello
I am looking for OCR example which uses WebCam (Microsoft compatible with LabView) for  digits recognition, I have found NI OCR example but it works only with bmp files. How to add WebCam support to this example ?
This example uses dark digits on white background, hot to modify recognition settings to work with white digits on dark background ?
Thanks!
(4,397 Views)
ok do it step by step
there a example in labview to how you can open your camera try to use it to get image from your camera
use IMAQ inverse vi to invert your image
attach example file to that image inside loop and develop it
in this case you can use labview example for your request
but also it is better to work with Ni OCR training software to create your own
character files to work with
(4,274 Views)
