Machine Vision
OCR many parts
Hello!
I'm reading, using the IMAQ OCR read text vi, many parts of many images. For this, I make an array of diferent ROIs, each ROI for of information I want.
BUT, although the images be of the same pattern, some small diferences appears, and the array of ROI stays out of sync!
The question is: there is a another way to read many parts of a text ou image? As the OCR contained in scanners ou something like....?
Thank you very much!
Filipe Palma.
(3,488 Views)
LabVIEW OCR is designed for reading a single line of text.  It doesn't do well at all on multiline documents.  It just isn't designed for it.  I would use the software that comes with a scanner if you want to use OCR on a large document.
Bruce
Bruce Ammons
Ammons Engineering
(3,485 Views)
humm.. OK! thanks
(3,396 Views)
I confirm the OCR has been designed to read one line at a time.
In order to detect each line, you may use the "Y Axis Averages" output of the "IMAQ Linear Averages.vi" (analysis palette).
Then for each line, build a rectangular ROI descriptor and use it as an input for "IMAQ OCR Read Text 3.vi".
Best Regards.
JC Benoit
Vision Engineer
Alliance Vision
www.alliancevision.com
(3,357 Views)
