Machine Vision
Object tracking not reliable
I'm using vision assistant express and it manages to track it in it but once I run my entire vi sometimes the bounding box tracks it on the side of the object or sometimes it tracks other thing that are not the object I want to track. My question is how can I make it more efficient so the bounding box stays in the object and doesn't loses it and tracks right
(2,856 Views)
there is many item that are important in this problem
but first you have to introduce the method that you use for tracking
(2,789 Views)
