Machine Vision
Octagon measurement
Hi there,
I'm trying to make measurements on an octagon.  I need to know the Max width, min width and center of mass.  I also need to evaluate the chipping on the side of the octagon (dark area on the side of the octagon). The chipping measurement must be made perpendicular from the side.  I would have use the blob tool if it would not have been the case.
I'm using
I thought of using the clamping tool but the measurement must be automated so I need to figure a way to build an algorithm.
Any idea?
Thank in advance
(3,279 Views)
My thoughts:
You can create a mask for the (ideal) entire octagon by converting it to binary, then use convex surface to fill in all the chips.
The ideal octagon can be converted to a depth gage by using IMAQ Distance or Danielson.
By manipulating the original image to get a binary image of the chips, you can combine it with depth gage to get distance from edge.
Bruce
Bruce Ammons
Ammons Engineering
(3,260 Views)
The problem is that the sides of the octagon are never the same length. the sidse can be longer/shorter than the mask.
as for the chipping, I tought of finding a straight edge of one side to start. then place the cordinate system on this edge and sweep ( one line ROI incremented by 1 pixel at a time from end to end of the side)  and check for the chipping.
what do you think?
(3,258 Views)
I think that your idea of sweeping the edge will work to check for chipping.  As far as actually detecting the octagon, you could threshold the image then use a detect object step to locate where in the picture the octagon is.  Then you could specifiy a coordinate system and then a mask or ROI based on this.  You could set the size of the ROI/Mask proportional to the size of the detected object and this should account for the change in size.
Greg H.
(3,241 Views)
