Machine Vision
OpenCV Facedetection
 I installed NIVision open cv utilities using VI package manager. But I am not able open the OpenCV Facedetection.vi .There is broken run button. If click on the run button SubVI 'NIVisOpenCV Facedetection.vi': SubVI is not executable.Again clicked on show error It shows subvi which is not executable. I am clicked on subvi for open front panel, again clicked on run button of subvi front panel, it showing as error Call Library Function Node 'nivisocvsamples.dll:NIVisOpenCV_DetectFaces':Library not found or failed to load.
If any one knows please help me to solve this problem to open the code.
Message 1 of 12
(7,152 Views)
I tried to open open cv example codes. there will broken run arrow . I am not able to run the code. The error in .dll subvi, Please help me if anyone knows. I am not able identify the problem where exactly
Message 2 of 12
(7,112 Views)
i have tried in my labVIEW 2015 , but iam unable to find the NI OPEN CV utility folder, where all the library bin files are placed,
it give me the same error call library function node.dll
give me sujjestion what i do now?
Message 4 of 12
(6,496 Views)
thou i installed the open cv utility package but the there is some error
Message 5 of 12
(6,494 Views)
Hi Soomoro,
You are getting that error because you are not running VIPM as administrator, Ctrl+rightClick the VIPM EXE and select run as admin.
 I had the same issue and this solved it for me.
Regarding the initial forum issue - I have the same issue 😞
Run VIPM as AdministratorRun VIPM as Administrator
Message 6 of 12
(6,415 Views)
thankyou so much. i successfully found  the open cv utility folder in my machine,
but i tried it so many times it gives me the error of    " call libarary function node.dll"   i dont know how to call the libraries in labview?
 i dont know how to create dll files and how to  upload in labview??
can you help me pleaze ??
thankyou in advance
Message 7 of 12
(6,404 Views)
How to fix error "nivisocvsamples. dll" on NI LabVIEW Vision OpenCV Utilities
Message 8 of 12
(6,270 Views)
can i detect the face in video stream using open cv in labview without creating dll files??
Message 9 of 12
(6,266 Views)
i suucssfully installed the open cv.but it cant detect the face from video?
any solution??
Message 10 of 12
(6,243 Views)
