Machine Vision
Optimising the delay for seed growing
I am doing a project on seed region growing.
The VI is complete but the execution time ranges up to 6 secs .I am not able to reduce the delay.
The VIs are attatched,
Operating Procedure:
1. Run the Seed.vi
2. The image is read from a file.
3.Draw the roi and press set roi.
4.Double click at a point on the image.
5.the region grows....
Pls suggest  some method to reduce the execution time.
(3,406 Views)
Can you attach the vi for lv 8.0?
(3,404 Views)
I have atached the LV 8.0 versions of the VIs.
Pls reply
(3,399 Views)
 The vi is for 8.2 and not vi. No probs if you can just attach a screen shot..
(3,364 Views)
