Machine Vision
Out of memory with Find Concentric Edge 2
Hello all,
Weird problem. I have an application that acquires a 25Mp monochrome image and applies this subvi. It's running as a compiled program on multiple PCs around the world. We use 64bit Win 7 and 32 bit LabVIEW 2015 SP1.
Today I start up the original uncompiled version of the program. It acquires and runs as before, but when it gets to the Find Concentric Edge vi I get an 'Out of memory' error.
I can't think that anything has changed on the PC or in the code. Has anyone seen anything like this before? And more important, any suggestions for how to fix it?
(2,674 Views)
Have you checked to see if the code has changed or not for sure? I was looking around and found another forum post that gave some helpful tips in how to prevent memory leaks if you have not seen it before.
https://forums.ni.com/t5/LabVIEW/Labview-IMAQ-Memory-Leak/td-p/3744594
If possible, feel free to attach your code or any helpful screenshots so we can narrow down this issue.
Thanks!
-Brian J.
(2,647 Views)
It's been a while but I finally got this problem resolved. Yes, there was a change in the code elsewhere that transposed the annulus inner and outer values. In older versions of LabVIEW this didn't cause problems, but the improved Concentric Edge 2 vi isn't so helpful.
(2,595 Views)
