06-19-2006 10:17 AM
06-19-2006 11:10 AM - edited 06-19-2006 11:10 AM
Hi Pallen:
I did not look at your code, but have you tried longer shutter/exposure times to 'integrate' the varying light?
The images all looked fairly similar to me.
Is it possible to shield the cameras field of view from the fluorescents and use an alternative light source (LED's, incandescent).
Can you trigger the camera externally? Wonder if a circuit could be rigged up to provide a synchronous trigger signal at the peaks of the AC power that is going to the lights.
Message Edited by AnalogKid2DigitalMan on 06-19-2006 09:13 AM
06-19-2006 11:34 AM
06-19-2006 11:50 AM
06-19-2006 12:03 PM
06-19-2006 12:31 PM
06-19-2006 01:02 PM
06-19-2006 01:40 PM
06-19-2006 02:03 PM
06-20-2006 07:22 PM
