Machine Vision
Overlay Settings valid only once
When setting an Overlay group (IMAQ Set Overlay Properties.vi) to transform WITH an image when transformed, this works fine the first time.
From the second time on (second transformation - I actually tested with symmetry) the Overlay no longer moves with the image.
I have falied to see where the settings need to be set after EACH transformation.....
I would have thought that the settings would stick.
Shane.
(3,522 Views)
I was trying to re-create this problem with an Example VI and I couldn't.
After much head-scratching I realised the mistake in my original code.
The Overlay Settings work indeed as expected.  I had a small mistake in my code which led to me re-setting the Overlays inadvertantly.
Shane.
Message Edited by Intaris on 06-02-2009 08:14 AM
(3,492 Views)
Hello Shane,
nice to hear.
Regards
Rüdiger
(3,486 Views)
