Machine Vision
Overlay convex hull outline
Hello there,
I'm quite new to LabView.
I'd like to overlay the outline of a particle's convex hull to the original image to see both, the convex hull AND the original image.
Can anybody help me out with this?
(3,695 Views)
Here's a way to do it.  There may be easier ways, but this should work.
Start with your original binary image.  Call this ORIGINAL.
Perform the convex hull operation with a new destination image to preserve the original image.  Call this HULL.
Perform a binary dilate command on the new image with a new destination image.  Call this DILATE.
Subtract HULL from DILATE to get the outline of the hull.  You could also use XOR.  Call this OUTLINE.
Multiply OUTLINE by 2 to make it a different binary value.
Use OR to combine OUTLINE and ORIGINAL.  This will look pretty good using the binary palette to display it.
Bruce
Bruce Ammons
Ammons Engineering
(3,682 Views)
Thanks for your reply!
I'm going to try it. But I've got one more question:
I already found a similar solution for my problem yesterday, where the outline was somehow written to a ROI and then overlayed. But I'm trying to overlay the snapped picture of the camera with the convex hull outline, but somehow it didn't work this way.
(3,675 Views)
You could probably use overlay bitmap instead of OR on the last step.  In this case, you would need to multiply by 255 instead of 2 so that the binary image is visible.
Bruce
Bruce Ammons
Ammons Engineering
(3,656 Views)
