Machine Vision
PC freeze every 7 days
Hello
I'm using camera card NI 8242 and Basler camera acA2040-90uc and it is use for vision inspection. The PC (DELL IPC 3000) keep getting freeze every 7 days. Any idea why this is happening?
(1,992 Views)
Hello Samkey
What is your RAM size ? and Does the PC freeze when your .exe is running or it happens everytime.
If it happens when your application is running, check for memory leakage in the application you have developed.
Check How much memory your application consumes using Task Manager.
-Rahul
Hit KUDOS for thanks
(1,904 Views)
