Machine Vision
PCI-1409 change the channel
hello,
i'd like to switch between two different camera channels and save the pictures in two different buffer.
this message is nearly the answer...
http://forums.ni.com/ni/board/message?board.id=200&message.id=1228&requireLogin=False
but the problem is, that i have to use c/c++ and in the folder 'samples/msvc' is no example for
switching channels while still aquiring.
has anybody a hint for me?
thank you very much,
malte
Message 1 of 1
(2,891 Views)
