Machine Vision
PCI-1410 video inputs with BNC-2090
We need 2 video inputs on a PCI-1410. The first one goes to the on board BNC connector. The second one needs some external BNC connector too. Is it possible to use a BNC-2090 box to access the remaining video inputs?
Thanks in advance,
JP
(2,988 Views)
Dear physicien nocturne,
You will not be able to directly connect the PCI-1410 to the BNC-2090 due to differences in the pinouts and connector types for the two devices. It looks like the 2090 uses a standard D-type connector and would connect to a MIO (Multi-function Input Output) DAQ device using a SH6868 cable.
See the BNC-2090 user manual, page 2-7, for more information:
https://www.ni.com/docs/en-US/bundle/321183a/resource/321183a.pdf
To access the signals from the VHDCI 68 pin connector on the 1410, you could use one of the options listed here:
Cables for Analog Cameras:
https://www.ni.com/en-us/shop/category/cables.html?productId=118167
or you could make your own custom cable according to the specifications found in Appendix A of the 1410 User Manual.
Hope this helps!
Best Regards,
~Nate
(2,964 Views)
