Machine Vision
PCI-1422 board not detected
I am having a lot of trouble getting my computer to detect this piece of hardware.
I installed IMAQ, but MAX dosen't detect that the 1422 is attached.
In fact, it dosen't even give me the option to add or configure any IMAQ devices, because IMAQ is not
listed under the "devices and interfaces" option. I have added the nessecary camera configuration
files to the IMAQ directory, but when I connect the camera I get nothing.
I've gone through about three different versions of IMAQ, the last one I installed was from the
Vision 8.2.1  package. I'm not really sure where to go from here.
Any help would be appreciated.
(3,746 Views)
Can you see the IMAQ in MAX  software list?
Maybe it not install correctlly
 Or you can change another  PCI slot  maybe  the solt the promble is....
goog luck!
(3,736 Views)
Does the card show up in Window's Device Manager? Not necessarily as an NI product but just as some board that the computer detects. If not, then there's something wrong with the board or the slot. If you can see it in Device Manager, try manually connecting the card to the IMAQ driver.
(3,727 Views)
