06-30-2005 08:23 AM
07-01-2005 12:28 PM
07-01-2005 10:06 PM
Hello Robert
The reason is the camera file, I tried the IMAQ3.0 but it does not work with the camera file, and I haven't fixed the camera file. The LABVIEW is good to use, but I have to use Visual Basic. Can I use the API(IMAQ.DLL) functions to solve the saving problem? | ||
07-06-2005 07:37 PM
Hi trinight,
If you have an older camera file, I would recommend seeing if we have that same camera file available on our website or if it downloads with the driver. What camera are you using?
Yes, you can use the API to interface with the driver. The most recent version of the IMAQ driver (3.1.3) has great support for Visual Basic, with many different example programs.
Additionally, many times the newer driver version will actually go through and update the camera file. Sometimes, for extremely old versions, this does not work.
Maybe we can use both a newer camera file and newer driver. In my opinion, it might make the programming process a little simpler.
Robert
