Machine Vision
PCI 1427 INPUT HARDWARE CONFIGURATION
Dear all,
   I am using the PCI 1427 for the first time so i am having some queries.
1.In PCI 1427 the inputs such as A and B,in the manual its mentioned as range as 5.5V,So the difference between A and B should be 5.5V or Difference between A and Ground should be 5.5V and difference between B and Ground should be 5.5V
Rajkumar,
Sr.Development Engineer
(3,131 Views)
The difference should be 5.5V b/w A+ and GND or B+ and GND. If you're using these inputs in Differential Mode, the limit is 5.5V between A+ and A-, and B+ and B-.
Vaibhav.
(3,112 Views)
