Machine Vision
PCI-1428 Advanced Look-up Table Test Failed
I just installed a PCI-1428 and ran the diagnostics in MAX and it says "Advanced Look-Up Table architecture test: failed" under the 'In Depth' diagnostics radio button.
When I click on the 'Details' button, it says "Look-Up Table returned an incorrect value. Check data lines. [L1.1]"
I don't yet have a camera to connect to the board. I have LabView v6.1 installed, but haven't yet purchased the Vision Developer Module, so that's not yet installed.
Is this a normal error because there is no camera connected, or is there something wrong with my board/system/software?
Thank you for your help!
Sincerely,
Neville Bonwit
(2,941 Views)
Neville -
This is not a normal error - the hardware should function correctly independent of the software or camera, as long as the NI-IMAQ driver is installed. Try running the diagnostics again - does it still give you the failure? If so, you may want to call NI to see if the board needs to be repaired. To do this, go to www.ni.com/ask and select the Phone NI option.
-Julie
(2,941 Views)
