Machine Vision
PCI1411 TRIG out
I have a need to use the TRIG TTL I/O connector on the PCI-1411 to trigger other equipment.
My thought is to send out this signal from LabView. Where can I find information on how to do this ?
I've controlled digital I/O before using DAQ cards, but how can I let LabView know I'm taking about the TRIG connector on my PCI-1411 card ?
   ak
(3,131 Views)
You will need to use the IMAQ Generate Pulse VI which is located on your Controls Palette»Vision and Motion»NI-IMAQ»Signal I\O»Generate Pulse. This will allow you to generate a pulse signal on a trigger line. This document may be very helpful to you: http://digital.ni.com/manuals.nsf/websearch/AA325865860F47A78625678400726482?OpenDocument
-Zach
(3,119 Views)
