Machine Vision
PCI1428: image acquisition directly to hard disk instead of acquiring to system memory possible?
Is it possible to stream the acquired images directly to the hard disk instead of acquiring the data to the system memory?
The problem is that IMAQ uses only 64MB out of 1GB (why?? at least additional 260MB are free) for image acquisition. This memory space is not sufficient for the number of images that I need to acquire. The only way out is to stream the data directly to the hard disk.
I do not want to loose the time after acquiring one image for the saving of the image from system memory via LabView to the disk. I need a continous series of images acquired.
I use a raid system that should sustain the data rate from the camera.
Thanks for your help!
Message 1 of 1
(3,058 Views)
