Machine Vision
PCIe-1433 with camera MC1362 (Mikrotron)
I would like to use my camera MC1362 (Mikrotron) with the frame grabber PCIe-1433. But this camera is not yet suported by NI, so I don't have any camera file for this camera. I tried to use the one done for the MC1310 (I have seen people on this forum who had used it with the frame grabber PCIe-1429 with success), but it didn't work too. I tried then to make a camera file with the camera file generator provided by NI, it didn't work too (no error message, but no image also!).
does anybody have successfully made a camera file for this camera and this frame grabber? Is it possible to obtain one from NI engineers, please?
Thank you in advance,
Bests
Message 1 of 11
(6,892 Views)
I just put a new Camera File Generator on the FTP site, which fixes some issues earlier versions had with the 1433. I would try this again to see if this works any better.
https://download.ni.com/#support/imaq/pc/ni-imaq/cfgenerator/
If this doesn't work, we could help you develop a camera file. If you could provide your contact at Mikrotron, I could try to get a loaner camera to develop the camera file for it.
Brad
Message 2 of 11
(6,891 Views)
Hi Brad,
thank you very much for your quick answer. I already tried this camera file generator this afternoon, without any success, unfortunately. I have the mail of technical support from the dealer of this camera in The Netherlands: support@datvision.com
I don't know if they really can help with that...
Thank you very much anyway!
bests,
David
Message 3 of 11
(6,886 Views)
I contacted support for Mikrotron and it didn't sound like they could provide a camera very quickly and they could let us have it for very long. Would it be an option to send you camera here? Or you could provide your contact info to vbai.support@gmail.com and I can contact you to try configuring NI Camera File Generator to acquire images.
Hope this helps,
Brad
Message 4 of 11
(6,839 Views)
Hi Brad,
I am in contact with someone from Data Vision, the dealer of Mikrotron in the Netherlands. He told me that NI had requested a camera for 4 weeks, and also I should be able to make a camera file myself (So, it is not a priority...).
I can try next week to make a camera file with your help. I sent you my contact info by the email adress you gave me. How long would you need my camera if I sent you it?
Thank you for your help,
Bests,
David
Message 5 of 11
(6,826 Views)
Hi
I am just setting up to do the same - imaging with a Mikrotron MC1362 and a PCIe-1433 framegrabber.  Did anyone have any success making a working camera file that I could use?
Mike
Message 6 of 11
(6,639 Views)
Hi Mike,
I can send you the camera file I use monday. It is not complete, but it helps to make it work. Be carefull with the number of taps selected, the camera file generator does not support 10 taps 8 bits. Brad send me an update for the camera file generator.
Send me your email, I will send it the files.
Bests,
David
Message 7 of 11
(6,632 Views)
Hi
We would need a camera file for the same combination of camera and framegrabber. Did anyone succeed in creating such file?
Regards
/Martin
Message 8 of 11
(6,412 Views)
Hi David,
I'm setting up a equipment with the same devices and the frame grabber does not reconize the camera. Can you help me eith the icd file? Did you was able to make it works?
Thanks in advance,
Maite.
Message 9 of 11
(6,299 Views)
Dear David,
I am new to use labview frame grabber, and also trying to apply PCIe-1433 with camera MC1362 (Mikrotron). would you like give me some suggestion to make the camera file or could I have your file to make them work.
Any suggestion would be highly appreciated.
Hao
Message 10 of 11
(4,511 Views)
