Machine Vision
PCIe1429 failed initialization
Dear everyone,
I installed PCIe1429 in the desktop PC( windows 7 64bit, Intel core i5-3550, RAM 8GB, mainboard ASUS B75M with LABVIEW 2010) and installed NI Vision acquisition SW (september 2011). after that, I executed NI measurement & automation explorer 5.0.0f1 and open "device and interface", but the program give me a message as following:
"The following IMAQ devices failed initialization:
Serial number 0x00000000
Error 0xFFFF3CAD: The error code passed into imgShowError is unknown.
please contact National Instruments for technical support."
However, there are no search result about 0xFFFF3CAD, so I have no idea to resolve the error.
Can anyone explain the meaing of the error code and give me a solution to resolve the problem?
(4,266 Views)
I have the exact same error, with labview 2011 SP1 on a Gigabyte P35 motherboard with core2 duo CPU.
Any idea how to fix this problem?
(4,114 Views)
Same problem here as well
W7-64bit
LabVIEW 2010 SP1
IMAQ 4.6.1
IMAQdx 3.9.1
Max 5.0.0f1
Did you manage to solve the problem?
Was it motherboard related as in
http://forums.ni.com/t5/Machine-Vision/Boot-failure-after-1429-card-installation/m-p/499149/highligh... ?
(3,992 Views)
The only way I have been able to get the card to work is to use labview 8.6 or earlier
(3,977 Views)
