Machine Vision
PCIe1430 Camera Channel Addressing
I am using the PCIe1430 succesffully from MAX to acquire images from two Pulnix Color Cameras (TMC-1400CL). In my Labview Code also I could read the image information fine from the Port 0. But I havn't been able to figure out how can I address the camera connected on the other Port, which is Port 1.
I would appreciate if you guys could send me a vi showing the addressing format for the two ports. (I have tried img0:port0 etc but it didn't seem to work)
Thanks in advance.
(3,508 Views)
K_seeker,
Have you tried...
img0::1
This should work.  If it doesn't, tell me.
Good Luck,
Lorne Hengst
Application Engineer
(3,497 Views)
Yes. I got the response from NI. So for the record, "img0::0" is the interface name for camera connected at port 0 and "img0::1" is the same for port 1.
(3,494 Views)
