Machine Vision
PPC2215 showing screensaver while monitoring data
Hope there is a simple solution to above problem.
I am using PPC2215 to monitor 24/7 process data. After about 30 minutes, screen go blank. I touch the display screen and it then shows the application front panel. Can I get rid of this problem?
Kind Regards
Austin
(3,212 Views)
Hi Austin,
I have tried to look into the device you mentioned, the PPC2215 but it did not come up with anything. I believe this is a third party device so it would be difficult for us to know the problem and how to fix it.
Shalini B
National Instruments UK & Ireland
(3,200 Views)
My mistake. Its PPC2115. You could view it here http://sine.ni.com/nips/cds/view/p/lang/en/nid/204134
(3,197 Views)
Any chance that in XP the monitor or power save settings are set to put the display to sleep after 30 minutes?
Just a shot in the dark (monitor).
-AK2DM
(3,192 Views)
