Hi Robert,
YES THIS WORKS BUT NO HELP - When you choose Open Interface, you should be able to select a particular camera file. After you select the camera file, it will return to MAX and the Channel name will change from (in example) chan0: Pulnix 1300 to Chan0: Pulnix 1400 CL.
MY QUESTION WAS ACTUALLY ABOUT WHAT TO EXPECT WHEN I DO "OPEN CAMERA", SEE CAMERA FILES.ICD, SELECT ONE AND THEN WHAT ??? NOTHING POPS UP - SHOULD IT?
I'LL TRY LOADING FROM THE CD AGAIN OR DOWNLOAD TO SEE WHAT HAPPENS - If the camera previously worked with the 1300 camera file, then the first step to getting it to work again is to find out what was changed. If you have made and saved changes to your camera file, you might need to start anew with a clean copy. The camera files that are shipped with the driver can be found at: ftp://ftp.ni.com/support/imaq/camera_support/camera_files/
ARE YOU CERTAIN AS I DON'T SEE ANY REFERENCE TO 10 BIT OPERATION ON THE 1428? - The 1428 should certainly support 10 bit capture. The only thing that will affect this are the current settings selected for your acquisition. These include the settings in Measurement and Automation Explorer and the settings defined by your camera file.
HOW DO I LOOK AT THE OUTPUT OF MY CONNECTION - PUT A SCOPE ON THAT END OF THE CABLE? -If you are receiving an error regarding the recognition of your video source, and you have already checked the cables, power, and have restarted your computer, you may want to look at the output of your connection and ensure that the board is receiving the proper video signal.
I'VE ALREADY DOWNLOADED AND INSTALLED THE LATERS IMAQ - Another thing that has not yet been mentioned is that you may want to check your driver version to be sure it is the most recent version available. As of this date, the most recent driver version for NI - IMAQ is 3.1 and can be found at: http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BE60070436D?opendocument&node=132060_US
Pachacuti
