Machine Vision
Particle filter no different? try to ignore particles less or equal 2 pixels
I have an image, I use Vision builder to identify particles,
Attached are the VIs generated by V Builder and image.jpg. I run the particle analysis with and without particle filter, the number of particles is 17 no matter what?
(3,099 Views)
Your parameters for the particle filter are reversed. If you swap the 0 and 2, everything works fine.
One interesting observation is that the upper limit is not included, so these settings only eliminate single pixel particles. To eliminate 2 pixel particles, you need the upper limit to be 3 (or it could be 2.5, etc.).
Bruce
Bruce Ammons
Ammons Engineering
(3,099 Views)
Thank Bruce,
It works fine now.
(3,099 Views)
