Machine Vision
Pattern analysis question
I have stitched two images (previous and current frame) into one big image for analysis (online). When working with big objects the method is efficient. the problem arises when objects are smaller and I get the same object two times in the stitched image. What is the best method to use to disregard the reappearing object from the analysis. Has anyone some ideas?
Message 1 of 1
(2,993 Views)
