Machine Vision
Pattern of Recognition
Hello Eden,
Sorry for using this thread, I will open a new thread after some time. However the reason why I am posting it here again is, you know what I am trying to do and I think you can answer me very well Smiley Happy
I am trying to do now is
1) Detecct the solar module if I rotate the picture at any angle, code can still find there are the matching cells.
2) The image I have upload, reference cell could be the same but if I choose small width or biggher width cell as my origional image and run the code to find the cell location with different width or size solar cell, is there any way the code can produce the same result.
3) Different intensity,  as you can see the attached image is almost dark and for locate the cells, i have to maximise the intensity of image. Is there any way that witout changing the intensity code can produce the same result.
4) Different picture, if I upload the entirely different picture. Is there any way to produce the same result.
I really want to give myself a try and make the program myself but I do now know where to start. If you can tell me which VIs can be helpful to perform these tasks. it would be very kind help. Thank you
With regards,
Lazer
Message 11 of 11
(866 Views)
