Machine Vision
Picture to IMAQ Read Barcode
I used camera iRayple to detect OK or NG barcode, and i have the problem, the output from iRayple is Picture and when i want to use IMAQ Read Barcode the data is not connected and wrong wiring
I want replace the Vision Acquisition with the Picture
How can i direct from Picture Pallete to IMAQ Read Barcode Pallete?
(563 Views)
Just get pixels in 2D Array from your Picture, then using IMAQ Array to Image to convert this array to IMAQ Image, which is needed for IMAQ Read Barcode. You must be careful with Image Data (I mean RGB or Grayscale), that is.
(539 Views)
