05-06-2009 11:12 AM
Hi, I have jast bought a couple of PL-B781G and this is the first time I use GigE cameras. They are connected to the PC thru an Ethernet switch. I can grab and display images using pixeLINK LV SDK. But I cannot snap images by MAX. I can see both the devices under NI-IMAQdx Devices but when I try to snap appears the error message attached.
Does anybody knows this error?
I have to develop my camera driver in LV. Do you suggest me to use LV SDK (pixelink APIs basically) or NI-IMAQdx?
Thanks a lot.
05-07-2009 10:44 AM
Hi Logatto,
are you sure that the Ethernet switch you are using supports the Jumbo Frames?
All hardware in a particular system must support Jumbo Frames in order for the data to be transferred in that manner.
For more information you can have a look at the documents in this link and this one.
Serena M.
