Machine Vision
Please help me about the IMAQ function.
I need to use the gray scale function, but need to show the image in color mode.
Now I'm trying to use the extract color plane mode function and copy image function,
but it did not work because the image still showed in gray scale mode, not color.
Any help will be very appreciated.
(3,542 Views)
Hi
I would guess that you have not created a separate image for the extracted greyscale plane. The images always need a destination to go to otherwise they overwrite. I have included some very simple example code to show what I mean.
Hope that helps
Mike
(3,536 Views)
Thanks Mike for your help. However, I can't open your example file. Could you please save it to LV7.0?
(3,531 Views)
Here it is again.
Sorry
Mike
(3,518 Views)
