Machine Vision
Pleora iPORT NTx GigE UART interface
I am using Pleora iPORT NTx GigE for my camera system and would like to send some some command through the UART Bulk 0 interface. From the NI Vision Acquisition Express, I am able to see the configuration as shown in the attach image but i can't seem to find any control to send command. Is there a way i can access the port communication in Labview to send command line?
(2,756 Views)
Hi Cadmon
Your post was some time ago but...
I have the same problem with a Pleora CameraLink frame grabber (model CL-U3).
It seems others have too in the past  https://forums.ni.com/t5/Machine-Vision/IMAQdx-and-Pleora-iPORT-CL-serial-RS232-link/m-p/3338486
Did you find a solution? The only way I can see is to replace the NI IMAQdx interface with .net from the Pleora SDK.
Cheers
(2,328 Views)
