Machine Vision
Problem building Smart camera application
I'm having a curious problem with an application that I've programmed for an NI-1762 Smart Camera. The application runs when connected to the development system, but when I try to create an executable it appears to corrupt the original file. The executable doesn't run on the Smart Camera, and when trying to start the original program from the Dev Sys the connection hoses up and the program doesn't run. Copying the code to a fresh vi appears to alleviate the problem. Does anyone have any thoughts as to what I might be doing wrong? I'm using Labview 10 with RT and Vision.
(3,596 Views)
Hi John,
I haven't heard of this corruption before. Are you able to pinpoint the specific area in your VI that is getting corrupted? When you say that the connection hoses up, what do you mean exactly?
(3,583 Views)
