Machine Vision
Problem converting JPEG string to IMAQ image
Hi, I'm using the JPEG decode VI to decode an image string i'm receiving from a Blackfin Camera. This works fine when i run VI itself but when i use it as a sub-vi the program crashes .Anybody have any advice??
This is an image of my program
Free Image Hosting at www.ImageShack.us
this is how the file is returned from the camera
'I''##IMJxs0s1s2s3....'grab JPEG compressed video frame
x = frame size in pixels:
1 = 80x64, 3 = 160x120, 5 = 320x240, 7 = 640x480, 9 = 1280x1024
s0s1s2s3=frame size in bytes (s0 * 256^0 + s1 * 256^1 + s2 * 256^2 + s3 * 256^3)
.... = full JPEG frame
Note that sometimes the 'I' command returns nothing if the robot camera is busy, so the 'I' command should be called as many times as needed until a frame is returned
I modified the JPEG decode VI by switching the red and blue colour planes. I dont know whether this caused the problem though.
(4,589 Views)
Accepted by topic author shadowzero2
(4,582 Views)
Hi, I finally got a chance to try out your code and it works perfectly thanks alot.
(4,520 Views)
I posted an idea request for a function to convert strings back to images.  Please vote for it at:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-function-to-convert-string-to-image/idi-p/1104573#...
Bruce
Bruce Ammons
Ammons Engineering
(4,020 Views)
