@Scott R wrote:
Justin,
So adding VB support for Vision 7.1 causes all of your IMAQ/Vision ActiveX controls to fail, but if you just install VB support for IMAQ 3.0 without support for Vision 7.1, the controls function properly?
Scott R.
Correct... Only installing the 7.1 core components and the 3.0 core components + 3.0 vb support will create functioning ActiveX controls that I can install into a new C++ project.
If I install the 7.1 core components + 7.1 vb support + 3.0 core components + 3.0 vb support OR 7.1 core components + 7.1 vb support + 3.0 core components then I can add the cwimaq control, cwimaq viewer control and then the vision control... I will crash out of the dev environment when trying to add the cwimaq vision control classes. HOWEVER, if I try to add the 7.1 controls into visual basic 6.0 they work just fine. In C++, adding the 7.1 vb support (build 0) creates havoc!
Justin
