Machine Vision
Problem in using sterio vision camera
I brought model bumblebee2 Bb2-03S2C of sterio vision camera 8 years ago. At that time it worked with window xp. Now I want to know will it be compatible with window 10.If yes how?
(2,706 Views)
Since this is not a NI (National Instruments) product, you might want to ask elsewhere first. (Are you using NI software to control it?)
(2,664 Views)
The product is officially supported by NI. You might want to check the compatibility of your framegrabber.
http://sine.ni.com/apps/utf8/nipc.product?pid=8395&asid=1102
(2,628 Views)
That page say it's "compatible" with NI products and shows a link to "contact Point Grey Research". That's where the needed "support" is. 😉
(2,612 Views)
